AirPort Board
17 Answers 7 Score |
MacBook shuts down randomly with still battery charge left |
12 Answers 7 Score |
My MacBook Pro has a black screen at startup. |
8 Answers 12 Score |
How to remove small scratches on the retina display? |
6 Answers 11 Score |
Correct battery clibration after replacement |
Documents
Parts
- Apple MagSafe 2 AC Adapter
- MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
- MacBook Pro Retina (2012-2015) Lower Case Screw Set
- 2.5" Hard Drive Enclosure with USB 3.0 Cable
- MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet
- MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker
- MacBook Air (A1369, A1466) MacBook Pro (A1425, A1502, A1398) Key Caps
- MacBook Pro 15" Retina (Mid 2012-Mid 2015) Keyboard Backlight
Tools
- Spudger
- Tweezers
- iFixit Opening Tool
- Anti-Static Brush
- Microfiber Cleaning Cloths
- Phillips #00 Screwdriver
- iFixit Thermal Paste
- Plastic Cards
- TR8 Torx Security Screwdriver
- P5 Pentalobe Screwdriver Retina MacBook Pro and Air
- T5 Torx Screwdriver
- Metal Spudger
- iFixit 6 Inch Metal Ruler
- T6 Torx Screwdriver
- Adhesive Cleanup Kit (Set of 12)
- Utility Scissors
- Arctic Silver ArctiClean
- iSesamo Opening Tool
Models
A1398 (EMC 2512 MacBookPro10,1) 2.3 GHz, A1398 (EMC 2512 MacBookPro10,1) 2.6 GHz, A1398 (EMC 2512 MacBookPro10,1) 2.7 GHz
Identification and Background
The MacBook Pro with Retina Display was released June 11, 2012.
The MacBook Pro with Retina Display is not labeled "MacBook Pro" on the bezel like previous generations, instead it is labeled on the bottom of the computer along with the model number A1398. This is the first iteration with flash storage instead of a hard drive.
The MacBook Pro with Retina Display is thinner than previous models. It has two USB 3.0 ports, one on either side of the machine, two Thunderbolt ports, and a MagSafe 2 power adapter. This model also sports an SD card reader and and HDMI port.
Technical Specs
Display:
- Retina display: 15.4-inch (diagonal) LED-backlit display with IPS technology; 2880-by-1800 resolution at 220 pixels per inch with support for millions of colors.
Storage:
- 256GB, 512GB, or 768GB Flash Storage
Processor:
- 2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Memory:
- 8GB or 16GB of 1600MHz DDR3L onboard memory
Wireless Connectivity:
- 802.11n Wi-Fi wireless networking;3 IEEE 802.11a/b/g compatible
- Bluetooth 4.0 wireless technology
Graphics and Video:
- Intel HD Graphics 4000
- NVIDIA GeForce GT 650M with 1GB of GDDR5 memory and automatic graphics switching
- Thunderbolt digital video output
- 720p FaceTime HD camera
Battery:
- Built-in 95-watt-hour lithium-polymer battery
Ports:
- Two USB 3 ports (up to 5 Gbps)
- Two Thunderbolt ports (up to 10 Gbps)
- MagSafe 2 power port
- SD card slot
- HDMI
- Headphone port
Dimensions:
- Height: 0.71 inch (1.8 cm)
- Width: 14.13 inches (35.89 cm)
- Depth: 9.73 inches (24.71 cm)
- Weight: 4.46 pounds (2.02 kg)
Additional Links
Apple's Product Page
MacBook Pro (Retina, 15-inch, Mid 2012–Mid 2015) Service Procedures
